Looking for Owner's manual - 2007 Motor Trike conversion
I had not fount this and when I called MT I was told they were not available for the 2007. Thanks for the help
Steve I hope you have the Adventure conversion. This pdf only covers independent suspension Motor Trike models. If you have a solid axle conversion maybe someone else has an owners manual they saved. Let us know if you still need help.. :xszpv: :xszpv:
If you do have a solid axle unit maybe this will help.
http://www.junkmaster.com/kj5ix/MTServiceManual.pdf
I do have solid axle - got the service manual and the owner's manual, even for independent suspension, helps. How do I figure out what MT i have? Cannot find and labels. It is a 2007 1800 and as best I can tell the conversion was done at the time of purchase. Thanks for the help
Motor Trike never made an owner's manual for any of their solid axle conversions. The preventative maintenance sheet is all that was put out on them. One thing that is noteworthy to make sure you're aware of.. The recommended air bag pressure on this list is NOT accurate for a Goldwing SA kit. 1 up on a GL solid axle, baseline minimum air pressure in the air suspension should be 35 psi. The air bags are rated to 100 psi, so you're not going to over pressure them in normal conditions.
http://www.motortrike.com/docs/Preventative Maintenance.pdf
Thanks for the air pressure bag tip...I had been running 20 lbs per the sheet.
Sorry Steve but I don't know how to tell by looking which is a Spider and which is a 2+2. I do know the kit serial number is stamped into the differential input shaft housing on the top. One friend of mine took his seat off and found his. Another used a mirror and flashlight from under the trike. Guess it depends on if you have a way to get the trike up high enough to get under if that second method is even an option. :xszpv: :xszpv:
AndyX
AndyX
