Master Cylinder
Dont these stallions use Ford Ranger parts?
Have you got a picture of the master and booster?
Ordered one for a 2007 Ranger and it looks the same. Thx Rick
Ban news. There was a bunch of brake fluid that got into the brake booster and may have taken that out too. I'm going to drive it a while and see how it acts. The master cylinder was definitely bad as it was leaking a lot. We also found the differential back cover leaking so that will need to be resealed and it's not easy to get to. I'm going to have all the coolant hoses replaced while they have everything apart. They've been in there since 2008. It will go back in the middle of next month for all this. Oh well, I guess some maintenance needs to be done since it's 15years old with over 60,000 miles. Rick
If brake fluid has been leaked into a booster the booster is on borrowed time
The fluid will start eating the seal in the diaphragm, you can try removing the booster and flush it with alcohol followed by hot soapy water, then continue to rinse it with lots of clean water, if that does not work, replace it
2011Case
2011Case
