Motor question
Does anyone know if a svda distributor will work with a Brosol 30/31 carb on a single port motor. I have a 1600cc dual port with a Solex 30/31 carb and it works. It pulls enough vacuum but I don't know if the single port will. I The motor has the 009 distributor in it now and it runs fair but still has the little stumble. Any suggestions.
motor question
Yeah that's probably what I need to do. I guess I could do that and check for total advance. Thanks for the info_On my dual port the carbs pulls 10 inches of vacuum and it has a port on the intake just below the carb and I checked it and it pulled 21 inches of vacuum. I'll swap them tomorrow and see what happens. Wonder if I put a port below the carb on the single port if it would pull enough vacum.
Aircooled.net tech article says no. http://www.aircooled.net/vw-distributor-options/ . Don't know personally.
Easy way to find out is swap distributors from dual port to single port and drive it. 009 and SVDA distributor stems should be the same.
