New front tire
Oct 14, 2014
746
128
murray.ky usa
I have a 08 RSV/Hannigan kit and in need of a new front tire and was wondering if anyone was using the Avon trike tire that is made for the Harley. Cross referencing says it is almost the same size as the original tire. When I had my Goldwing trike I used one of the "trike tires " on it and liked the way it performed, but only got about 10k out of it.When I got this trike it had the original Dunlop 404 with 10k miles and was worn out but had worn very well, so I decided to try a 404 rear thinking it would last longer with the deeper tread. Now at 20k the tire is cupped badly and needs replacing. So I'm asking for some opinions on front tires! The Harley 'trike tire' is bias ply and 9/32 instead of radial 6/32 like the one for the Goldwing, so it might last longer. All opinions are appreciated!
If you got 20,000 miles of good service out of the D404, why do you want to change to another tire? :xzqxz:
The D404 is inexpensive and preforms well.:)
Ride Safe & God bless
I like the way it rides and it is inexpensive, but the 2nd one that I put on cupped really bad. It started cupping at about 3k and has worn very uneven and is very noisy! The only difference between the two is that one was a front tire and the other is a rear tire.
I'm just looking for other options.
I am using a D404 Rear Tire in a reverse rotation. I check the air pressure regularly, keeping it at 42 lbs. Present tire has 20,000 mile with no cupping.
I heard good things about the Avon Trike Tire. However, my dealer said they couldn't get it in the size I need.
I ran a Metzler 880 for over 20000 miles. I could have run another season, but it was 4 years old and starting to dry out. Keep in mind my RSV is mated up to a Motortrike with no rake. I change over to a metzler 888 this year.
Sylvester
Sylvester
