Jack Klarich
18000+ Posts
Here is StoneColds words from a beta tester of his latest fix
Those of you that have followed this thread closely know that I had sporty1234 testing venting "The Fix" through a small 1/16" hole in the seal case at the top. It seemed to be working, unfortunately he has experienced transfer with this set up. It is becoming more apparent that the only real cure for this problem is to totally seal off the transmission and primary. If this is being caused by a vacuum in the primary that is the result of an engine seal not containing the engine vacuum I think there must be something that is magnifying that problem, like the engine breathers. Anyway back to the subject, if you have drilled a hole in the seal case to vent the primary, check your transmission levels to make sure you're not still transferring.
Not very encouraging, BUT the man is trying darn hard to fix an under engineered problem JMO
