Power Commander for my 2012 HD Trike
Can any one with knowledge help me in determining how a power Commander will help on my 2012 HD Trike. I am looking at putting one on my HOG Trike. :Shrug:
The Power Commander can work, but it also can be a big PIA. I've seen them work well once a good tune is developed, and I've seen folks left on the side of the road when they go belly up. My tuner of choice is the TTS, it'll do way more than the PC and it won't leave you along side the road.
Ive been reading a lot on here bout the TTS, I have a 02 Ultra/MT conversion..
I have a power commander on mine and works great.. question is, since I have an older bike, will the TTS comply with mine.. I cant do all the fancy stuff that can be done with all the new electric that have come out..
The TTS will work with yours with the only exception being you don't have O2 sensors so tuning using V-Tune won't work. You would have to either put it on a Dyno or uses other devices to read the AFR. Right now if you have a perfect functioning PC I wouldn't switch for the sake of switching.
My suggestion would be for you to look at/review the Dynojet Power Vision, very user friendly and you do not require the use of a computer to run an Auto Tune session and load the results on the spot.
I have one on my 2013 V-Rod Muscle and my 2013 TriGlide with the 120r crate motor installed. I have both dialed in and running awesome (my opinion!). I am also getting credible fuel mileage.
Good luck with what ever your decision ends up!!
Roger
Sylvester
Sylvester
