Re: Progressive Fork Springs...soon to be my newest addition...
I will try that. Thanks sgtbush207
The issues on Progressive or stock (dual rate) springs versus Traxxion or Race Tech (single rate).
Dual rate sounds like a great idea. A softer rate for small bumps, a bigger rate for big ones. Thing is, on a heavy touring bike like the GL1800, most of the soft part of the rate on the Progressives is used up as the bike sags. Stock is worse, essentially all of the soft rate is used up. You also have to use more "preload" on the springs to get acceptable sag, which increases the very first part of the rate.
So, there's much to be said for just using single rate springs, to stop the bike from sagging too much, with less preload. It's a personal choice, but that's where I went.
It actually doesn't matter if you apply the brake or not.OK I tried to move the front end down with the front brake activated. The front moved down maybe 1/2". Pretty firm. Then activated the rear brake only. Could not budge the front end downward at all.
sgtbush207
