Rebel RT
RebelRouser
Gotta love my local (Long Beach Ca.) motorcycle swap meet every month, just scored a rear rim with mounts for disc and sprocket, 18x10w.HPIM5077.JPGHPIM5079.JPGHPIM5082.jpg
RebelRouser
Hoping to get the lower frame welded this week. HPIM5083.JPGI really do not like the offset of the tire and swing arm.
RebelRouser
OK, Feeling not to good about the welders not wanting to hold flatness, sooooo! I redesigned the lower frame to eliminate the 45 degrees (6 pieces) now it is one piece, wider for the suspension but that's OK. Can you believe the hardest part is cutting the 45 degree gussets for the control arms, DAMN cheap Harbor Freight chop saw...
RebelRouser-steering
Rack and Pinion center steer, any opinions? backlash? or stick to my go-cart style? Rack and Pinion center steer-Dan's 8inch.jpg Rack and Pinion-center steer.jpg
RebelRouser
Lower frame tacked welded, now to fit and then tack the mid frame and bring the swing arm into play...HPIM5692.JPG
RebelRouser
Now is the time to mock up the 2 sets of frame rails for the swing arm and looking at sprocket (Harley) clearance and what about the jack shaft? 2 sprockets Harley and Honda?View attachment 62609Does anyone have any input for jack shafts?jackshaft-ijn.jpg
RebelRouser
Rack and Pinion center steer, any opinions? backlash? or stick to my go-cart style? View attachment 62194 View attachment 62195
Stiletto Fast Ratio Small Box Rack and PinionThe ultra fast action of this rack-n-pinion is designed for small oval track or mini baja applications. Precision machined from high strength steel and billet aluminum. Close tolerance manufacturing processes have been incorporated in these units, resulting in a very smooth action, with near zero backlash.
For rear steer applications (steering arm relative to steering axis), mount in the position as shown. This unit may also be mounted inverted, for front steer applications. Considered to be one of the finest rack-n-pinions on the market, proudly made in the USA.
  • 7/8 Total Pinion Rotation
  • 4-1/2 in. Total Rack Travel
  • 11-1/4 in. Length
  • 5/8-36 Splined Coupler (Included)
  • 2.74 lbs.
RebelRouser
Tack welded frame rails, need fixture for alignment of 18 degree uprights, and aligning swing arm...HPIM5744.JPG
RebelRouser
I am in the process of making fixtures to keep the upper and lower rails square so I can weld the 18 degree uprights that tie them together and the swing arm/rim that is giving me fits...HPIM5747.JPGI emailed my Harley source of my problem so I will see him Oct. 28 at the LB motorcycle swap meet...
RebelRouser
Fixtures are welded and trial fit in place, should have taken photo of fixture by themselves, next time...HPIM5772.JPGHPIM5773.JPGHPIM5780.JPG
