ring an pinion
Nov 23, 2012
4
FORT LAUDERDALE
This may be the wrong place to post this, but I am sort of stuck between a rock and a hard place. My 2007 lehman Monarch ll needs a ring and pinion set. I know its a ford 6.75 rear. Does anyone know where to find one. Lehman most of the time does not return calls. I spoke to Cory over at Lehman and he told me that he was supposed to get some in a few weeks. I just need to know for sure, or have another avenue for this part.
I would try to find more info from tag on diff or from Lehman, then call nearest junk yard and find latest model available with front end crash. At minimum you could steal the gears out of it and swap with your bad ones. Or, look online and see if you can buy the gears.
Find all the info you can on exactly what rear it is.The former service manager at work does rear end rebuilds as a side job and really reccomends these guys www.randysringandpinion.com .Never know they may be able to help you i.d. it plus you would be able to get the same ratio.
Roadrunner1
Roadrunner1
