Get the Green Manual for the Spyder..If you want to do your own Maint. Helped me out.. ThumbUp
Thanks for the tip on the Green manual, will do.
They use a 6mm allen and t45 torx for the drains. 36 mm for the oil filterIf you are going to do your own oil changes... Just remember ' The plastic unscrews with a Torx's ' And the drain plugs with an Allen.... If you do use the Torx's on the drain plugs you'll soon be posting how the dealer/factory over tighten them and then they striped when i tried to change the oil... Very common mistake with Spyder newbes...
Must be the newer ones... The one i had was torx for the plastic and allen for the crankcase/oil tank/ and The oil filter was a canister type that also needed allen...
My wife traded her 12 for a 16 last Thursday. Says it's so much better.
white is faster and more comfortable
irv
Holy crap, I was wondering what was slowing my 'white' GW Road Smith down.
