Shovelhead 19t eng to 22t eng sprocket what size primary chain needed
Aug 16, 2015
350
205
ft worth
69 shovel rebuilt after piston hole,ive run a 19t eng sprocket for 40 yrs going to 22t to get more top end or so s i think but what length size primary chain is needed ???
80 82 thought i had a 80 in the bike but counted side plates an had 36 so s ya double that an get 72 maybe Mr jack can chime in he knows theses trouble heads
22t is what ole pan sidecar ran i think for gearing i dont run a compensator
thinking 22 will pull my 1000 lbs an a bit ok, since side car rigs run 1050lbs
ive called the shops and searched the net, no info on length of chain to date, thanks
69 shovel, 60 over wiseco pistions
andrews ab cam
sifton oil pump
swap meet heads worked with umbrella valve seals solid lifter pushrods ;)
not yet cant get engine timing done correctly yet or its the electronic ign i put on it
3k for rebuild and a yr waiting, wish id put in an evo i had
rvflorian
rvflorian
