Oh no Jack not offended at all sometimes tire mounting just goes bad machines and or people. Not worry Jack. Not you the tire are finicky LOLI did not know I was, sorry if I offended you or any one else, NOT my intentions
What is your make, model and year of bike? | Harley Davidson, Tri Glide Ultra, 2014 |
What are your tire sizes? | MT90B 16 |
Message | I purchased your AV91 Trike Tire on 06/02/20. These were purchased from and installed by Motor Cycle Accessories in Grand Junction. At first, I had a buzzing feeling in the hand grips between 50-60 mph. I had them rebalance the tire and same result. I took the trike to another motorcycle shop and had them rebalance it. The results were better, less buzzing but still in that 50-60 mph range. It almost seems to come and go depending on the road surface. Worse on chip sealed roads, best on concrete surfaces. Asphalt roads seem to be hit of miss. I'm running 40 psi in the tire. What do you recommend I do next? Thanks, Alan I also responded to his query about the rear tire pressure saying I'm running Goodyear Comfort Treads with 30# in the rear. We''ll see what they come back with. |
I had a front wheel bearing go South on my 2017 Tri and it started out sounding like a hum and went to a clicking later
I now have over 7500 miles on my 2020 & no problems with the Avon. :clapping:
Just throwing this out there as I have seen this happen :: Was the tire mounted proper rotation ?? Just a thought
