Speed bleeders for brakes
"Introducing SPEED BLEEDER® brand checkvalve, the patented bleeder screw with the built-in check valve. It is truly a one-person bleeder screw. Once installed, it becomes a permanent part of the brake system. When it is time to bleed your brakes, you loosen the Speed Bleeder brand checkvalve 1/4 turn and pump your brake pedal. When the pedal is depressed the pressure generated opens the check valve letting air and brake fluid out of the end of the Speed Bleeder brand checkvalve. When you release the pedal and it returns to the up position, the check valve closes and prevents any air from reentering the system through the Speed Bleeder. When bubble free fluid is evident you close the Speed Bleeder brand checkvalve. In the closed position it works just like your stock bleeder screw and prevents any brake fluid from leaking out. It generally takes about 5 pumps to purge each caliper or wheel cylinder. That is all there is to bleeding your brakes. If at a later date you need to bleed your brakes, the patented thread sealing system makes it easy to open the bleeder screw to perform the bleeding operation. It is made of quality materials and it is economical." $7.00 each
My point-Still pretty much a 2 man job on a trike. Hard to see the "bubbles" through the trike body!
YMMV. Lots of kudo posts for these out there.
My local installer uses a mighty vac. He makes it look easy but, then he's done hundreds!!
Drew73
Drew73
