Stalls going in-gear
Clutch activation is hydraulic, having air in it will lessen travel of clutch when you squeeze the lever. Sounds like you need to check fluid level and maybe bleed it, and check for leaks. Could be a bad seal in slave cylinder too.
Also, look at a bushing replacement where lever pushes on push rod end. If never done, good chance it needs a new one.
I'd look for leakage, check level, and bleed first.
1500 clutch
I tride to send you a privet message on a easy way to bleed your clutch but i can not send it to you for some reason if you want the info send me your email address and i will send it to you.
Thanks everyone. The fluid was low and probably had air in it. I tried the "quick bleed method" by pumping the lever and then tying it down overnite. Worked.
Roadrunner1
Roadrunner1
