Switched Accessory Plug
Jun 14, 2015
181
63
Yorktown, VA
Ok, I give up. Just got a 2019 model and the plug is not in the usual spot (under the left cover above the ecm programming plug). Can somebody help me out.
Thanks.
Owners manual shows a tri-glide fuse area with the accessory plug right above the ecm plug. Mine has no plug for accessories in behind the left panel. There's a wierd looking plug right a the base of the fuel tank with a plug in it, but it won't work with the [FONT=&quot]Electrical Connection Kit ([/FONT][FONT=&quot]2017 and Later Road King require separate purchase of 69201599A) Maybe the connection kit I got works only for Road Kings?[/FONT]
Connector #109
If anyone is looking to run passing/fog lamps the appropriate connector is located in the caddy l/h side of tank. It's a 4 place female( Male pins) Mate N Lok connector.This is for your toggle switch.Position 1-3-4 are used. 1= Red w/yellow tracer( power) black=grnd, blue/ gray tracer is accessory. Remove 2 acorn nuts from l/h signal nacelle panel and see 6 position connector #31.It has two empty slots for wire from switch connector. Or you can buy HD 69201108 harness. The riser cover has two plastic plugs on either side for your toggle switch(s). Pry up on triangular cheapo plastic trim. Remove two Phillips screws and pull riser cover back and up.Road King light bar works with Freewheeler.
rramo
