Tire pressue check cold or hot??
El Lobo
30+ Posts
Hello Gents
So yesterday i went out on a ride on my 2019 Tri-Glide. I checked the air pressure on the tires before leaving. and aired rear tires to 24 LBS / Front Tire ( American Elite Rear tire reversed) 40 LBS. After about a 20 mile ride I rechecked the tire pressure, the front pressure was 46 LBS / rear tire were at 26LBS. So my question is 46 LBS two much air pressure for the front? Thanks for your input.
El Lobo
Hello Gents
El Lobo
Tire air pressure;..101…..Always check When Cold…. The recommended tire pressure for the Triglides front tire is 36 pounds in the front tire cold!…
A good rule of thumb is that your tire pressure should increase "about" 10% after they warm up from riding (or driving anything). Lots of variables though. Your "cold" tires could have been checked in a cool garage and then take the bike outside into New Mexico heat and ride on the hot roads..... Or your gage may not be the most accurate and not produce good readings from one time to the next. I think T.P. reading should be checked and tracked a few times so you know you are getting consistent results. Once you know how your tires react to pressures when riding, you can confidently inflate to a good known pressure when cold and not worry. Motorcycle tires, especially rear tires, are very stout. I wouldn't worry about 46 PSI.....
Sylvester
Sylvester
