I'm back - I got the bearing races out using a piece of 3/8" steel rod (all is good with that) -
Here's my new issue: trike was level after the initial conversion - Now after installing a +6 degree raked tree, the front of the lower frame is now about 1/2 - 3/4 inch lower - The ? is will being slightly lower in the front be a problem with steering and/or create any other control problems? Would it be better to be level again or even very slightly higher in the front ? Any suggestions/comments would be greatly appreciated. Thanks!
