VANDERHALL: Debut of the Vanderhall Speedster
View attachment 85993View attachment 85994View attachment 85995 Shortened both ends of the rack by one section and my wheeled trunk fits great. Shortened the reciever tube about 1 1/2" and angle cut it to have more weld on the tube. I can still use the reciever for a ball mount if needed, just have to angle cut to fit the inner length of the tube. Rack from Harbor Freight and trunk (plastic) from Northern Tool. Tom
Hi Tom,
Nice looking set up for those short stays/trips where a cargo trailer isn't as necessary. I am curious how the receiver hitch is attached to the swing arm of your Carmel. It looks like there a hitch pin involved and if so, making it easy to disconnect I'm assuming, correct? Could you provide a close up picture of the attachment point when it's convenient?
pmar6004
Hi Tom,
pmar6004
Look closely at the photos as it isn't attached to the swingarm but bolts to the hub between the fender bracket and hub. All I did was change the end from a ball mount to a reciever tube so I could use the rack or slide in a ball hitch if ever needed. Tom
Tom, you have a very nice set up, perfect for those shorter overnighter trips using the luggage rack, or the more lengthy ones, where a cargo trailer is more appropriate. The Deadwood 3 Wheeler Rally is still on, scheduled for July 12th - 17th http://www.d3wr.com. You, your buddy Mikey and your significant others have my personal invitation and to participate in my Meet & Greet/Ride/Luncheon event that I'll be hosting on July 14th, 8:30 AM. This will be the 4th year that I've hosted this event, but the first year as a "Vanderhaller". Sure would be wonderful to see more, as I currently have 13 that have said they would attend, making up (3) Vanderhalls, (1) Slingshot, (1) Stallion, (1) Victory Trike, (2) Can Am Spyders and (1) Harley Tri-Glide.
pmar6004
pmar6004
Thanks Paul but not sure about any trips for awhile. Already cancelled my Americade trip for June as all of the group I would have been meeting there have cancelled! That trunk actually holds more than the suit case used prior and that was good for a couple of weeks for 2 when you did laundry every 4-5 days. It's 37" w x14" h x 17" d. On sale now at Academy Sports for $25. Very light weight. Tom
Venice Specs
These are the listed specs for the Vanderhall Carmel taken from the website.
Specifications
GENERAL
Passengers: 2
Body Construction: Composite
Exterior Colors: Silver Vintage Metallic, Poseidon Blue Metallic, Ruby Metallic, Pearl White
Model Year: 2019
Place of Manufacture: Provo, Utah
STANDARD EQUIPMENT
Convenience: Heated seats, dual-vent heating system, front entry doors
Safety: Dual servo-brakes with ABS, traction control, electric power steering
Interior Material: Saxony Brown V-Tex synthetic upholstery
Audio: Two channel, amplifier – with Bluetooth connectivity
Lighting: LED (headlights, turn signals, brake lights)
ENGINE
Alignment: Transverse
Manufacturer: General Motors
Engine Code: LFV
Cylinders: 4
Configuration: Inline
Displacement: 1.5 liters (1490cc)
Valves: 16
Bore x Stroke: 74.0 x 86.6mm
Bore Center: 81mm
Compression: 10:1
Redline: 6,500 rpm
Aspiration: Turbocharged
Horsepower: 200 @ 5700 rpm
Torque: 203 lb-ft @ 2,450 rpm
Block: Aluminum
Sump Design: Wet
Fuel Supply: Direct Fuel injection
Recommended Fuel: 91 octane
Catalytic converter: Yes
TRANSMISSION
Type: 6T40 (MNH)
Gears: 6
Driven Wheels: Front
Top Gear Ratio: .75
Clutch: Automatic torque converter
Final Gear Ratio: 3.87
PERFORMANCE
0-60 mph: 4.5 seconds
Top Speed: 138 mph
Lateral Cornering Stability: .95 G
Power-to-Weight Ratio: 7.9 lb/hp
CHASSIS
Suspension, Front: Pushrod, coil-over hydraulic shocks (Vanderhall)
Suspension, Rear: Single-sided swingarm, coil-over hydraulic shock (Vanderhall)
Base Wheels: 19x8.5 Front, 19x11 Rear
Base Tires: 235/35ZR19 Front, 275/35ZR19 Rear
Brake Calipers: 4 Piston
Brake Rotor, Front 315mm
Brake Rotor, Rear: 275mm
Steering: GM rack-and-pinion, electronic assist
BODY
Base Platform: Vanderhall Mono Aluminum
Bodywork Material: Composite
Cargo Capacity: 83 liters
DIMENSIONS, WEIGHT & CAPACITIES
Length: 3700mm
Overall Width: 1750mm
Track, Front: 1500mm
Height: 1140mm
Wheelbase: 2575mm
Weight Distribution: 75/25
Ground Clearance: 125mm
Dry Weight: 1,505 lbs.
Curb Weight: 1595 lbs.
Load capacity: 500 lbs.
Fuel Capacity: 9.5 gal.
I am waiting for a new Venice GT to arrive, and I'm wondering if anyone here has a list of specs like these for the Venice?
Sylvester
Sylvester
