vtx 1800 5th gear power
Mar 22, 2010
976
15
Nashville Mi
it seems most of my riding (2 up) is done in fourth gear. It seems it is "sruggling" in 5th gear.<br />
was considering getting a trailer but not confident it has the ummmphh to tow it in 5th gear.<br />
is this normal ? Champion trike
<div class="bbcode_quote">
<div class="quote_container">
<div class="bbcode_postedby">
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>meredog</strong>
<a href="showthread.php?p=31380#post31380" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">it seems most of my riding (2 up) is done in fourth gear. It seems it is "sruggling" in 5th gear.<br />
is this normal ? Champion trike</div>
</div>
</div>
</div>Have you lowered the final drive ratio as part of the Trike conversation & if so by what % ???
You should have plenty of power talk to your installer/mechanic
i have rode vtx 1800 trikes and there shouldn't be a problem
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>Baz</strong>
<a href="showthread.php?p=31389#post31389" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">Have you lowered the final drive ratio as part of the Trike conversation & if so by what % ???</div>
</div>
</div>
</div> ??????????? I purchased it new at a Honda dealer in Little rock Arkansas so i really don't know.
</div>
</div>
</div>
</div><br />
Is the drive ratio normally changed when converting ? Is there a way to check ? how is it done ?
<a href="showthread.php?p=31402#post31402" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">Is the drive ratio normally changed when converting ? Is there a way to check ? how is it done ?</div>
</div>
</div>
</div>Working on the basis the Bike manufacturer has the gearing about right for a bike then it can't be right for a Trike. Remember you have added a great deal of extra weight, rolling resistance, aerodynamic drag etc. I'm working on the basis that a reduction in final drive ratio of about 4 / 6% would be about right for most V twin engines of mid to large displacement but this is based on best educated guess not science at this stage. Not knowing anything about your engines state of tune there is a good probability that you are running far too lean (factory settings to get thru the emission regs ) under load & large throttle positions. A richer mixture will tend to see your engine develop a lot more torque which it needs to haul the increased load due to all the reasons above. For example--- A Ducati we own could not pull 6th gear 2 up @ 110 kph. After richening it up some by tricking the O2 sensor the bike pulls cleanly from 90kph to what ever. Heaps more torque & better fuel mileage.
<br />
I hope you can see where I'm going with this ??<br />
<br />
But to answer your question, I would expect the installer to know exactly what the drive ratio would be. Might be worth the phone call. Cheers Baz <img src="images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
PS I would be most interested in reading other opinions.
I very seldom get into 5th. Usually above 65 will let it run smooth. If you need more power for passing, I down shift and go.
I talked with RSmith yesterday about this and gas mileage. What it came down to was if the used a different gear ratio, then power would suffer and the bike would shudder all the time.
From their site.
Automotive Differential
Our differential is constructed from standard automotive ring and pinion gear sets. The original application of our differential was a Jeep. We cut down this cast iron housing and make an Independent Suspension differential out of it. The components inside of it are all new, including the 3.55:1 ratio ring and pinion. We make the gear ratio slightly deeper to retain the impressive power of this monster.
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>Smoken'JOE</strong>
<a href="showthread.php?p=31549#post31549" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">I very seldom get into 5th. Usually above 65 will let it run smooth. If you need more power for passing, I down shift and go. <br />
I talked with RSmith yesterday about this and gas mileage. What it came down to was if the used a different gear ratio, then power would suffer and the bike would shudder all the time.<br />
<b><u>From their site.</u></b><br />
<b><font color="Red"> Automotive Differential<br />
Our differential is constructed from standard automotive ring and pinion gear sets. The original application of our differential was a Jeep. We cut down this cast iron housing and make an Independent Suspension differential out of it. The components inside of it are all new, including the 3.55:1 ratio ring and pinion. We make the gear ratio slightly deeper to retain the impressive power of this monster.</font></b></div>
</div>
</div>
</div>hmmmmm Is yours a Champion trike ? I have an inquiry out thru my dealer and they are checking on it for me.
I have a solid axle with automotive style rear end but i do not know the gearing. (When the dealer said independent suspetion they explained : they mean't independent shock on each side------I didn't know the difference at the time<br />
I am expeirencing about the same thing --over 60-70 mph (on the level ) i can use 5th gear
<a href="showthread.php?p=31553#post31553" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">hmmmmm Is yours a Champion trike ? I have an inquiry out thru my dealer and they are checking on it for me. I have a solid axle with automotive style rear end but i do not know the gearing. (When the dealer said independent suspetion they explained : they mean't independent shock on each side------I didn't know the difference at the time<br />
I am expeirencing about the same thing --over 60-70 mph (on the level ) i can use 5th gear</div>
</div>
</div>
</div>Nope not a Champion, Roadsmith kit for me. I looked at the Champion site and they don't call out the ratio.<br />
<br />
<a href="http://www.championsidecars.com" target="_blank">Welcome to Champion Motorcycle Trike kits, Trike conversions, Hard Bags, Sidecars, Trailers, EZ-Steer, Reverse Gear</a>
From their site.
Sorry but the gearing has nothing to with the power. That's a function of the engine. The gearing should be set so that the Trike is running within the engines torque band or close to it is the theory. If you cant haul 5th gear then that's proof positive that the final drive ratio is wrong. On my trike for example it runs @ 3600 rpm @ 100 kph. As a bike the rpm @ 100 kph was 3100 I think. It hauls 5th gear from 90 kph easily . It will haul away from a standard M109R bike from a standing start. Why ?? because I lowered the final drive ratio to compensate for the substantial increase in mass that comes from Triking a bike. Fuel consumption is only marginally more than the bike . How come ?? because although the rpm is higher less throttle is required as the engine is less loaded due to the change of final drive ratio. Baz. :confused:
PS. If the Trike shudders surely that is indicative of gearing being too high for the load. Exactly what I have been trying to say. I struggle to accept that Road Smith don't understand this .
What would be a good gear ratio for the VTX 1800?
He said I could put a 3.08 in there but it would shudder through all the gears.
OR, do you think there is a different problem? :confused:
The Gold wing trike 1500 1997 will pull the 500 lb trailer 2 up no problem . RPM above 2,500 is no problem what is the RPM at say 45 MPH. that will tell the story . Compare it with other 1800 owners on here
One problem.....don't have a tach. There is a big difference between a GW and VTX. Flat 6 vs "V" twin.
There is a way to find the gear ratio. Jack up the rear tire so you can rotate it and see the drive shaft. mark the tire and the drive shaft. Turn the tire and count the revs. Help me now I am old , I cant remember if it is one turn of the tire and how many of the drive shaft or one turn of the drive shaft to how many tire., I believe it is the first. so u spin the tire 1 time and the drive shaft goes around 3 it is 3:08( very high gearing good fuel economy but no umph in 5th or off the line.) if it goes around 4 it is 4:11 great tire spinning off the line power and poor MPG. and if it goes 3 an 1/2 it is 3:55 and 3 3/4 it is 3:70 Both really good IMHO.Enough off the line and good power in 5th and gas mileage is not too bad either
OK my VTX 1800 @ 55 mph in 5th gear is running at 2400 rpm------at this speed going down a slight grade is fine on level it is shuttering going up a slight grade it needs 4th gear
Fair comment but you are comparing a 6 cyl engine to big bore long stroke V twins, the power characteristics are rather different & shudder under load is common with this arrangement. Therfore it needs to be engineered and / or tuned out as best you can. :)
PS I'm trying to get the specs re the factory VTX 1800 final drive ratio so I can compare all ratios to the M109R.
Not that i'm saying the M109R is perfect but you will have noticed the big difference in rpm between my Trike & yours at a similar speed give or take a few KPH. :yes:
From their site.
Here ya go. Trikes: HSC1800 : Roadsmith Trikes
From their site.
From what they're indicating, I'd expect the stock ratio to be about 3.25 or so. You're having the same problem some of us Harley guys are. It's called "lugging" & realy, a part of V Twins. I start getting that "shudder" at 2700 RPM in 5th & sometimes 4th if it's pulling hard. Of course, 2700 is almost dead on 55 mph in 5th. PART of my problem is the cams I'm running. S&S gear drive cams are good above 25 - 2600 RPM, so at 2700, I'm still too far down in the RPMs. At 2900 (65mph), it smooths out. One solution would be to go to HD 205 or 255 cams, but I'd loose the gear drive, which in the earlier twin cams is a GOOD thing. SOooo, I just pay attention to the engine & when it starts to lug, drop a gear & let it turn up a little. After all, 55mph in 4th is 3600 & 60 is 3800, well within the RPM range without getting into the heavier fueled range above 4,000. Don't know about you 'cause you haven't said, but in the lower gears, I don't get the shudder 'till down around 2000. Like I said, I have options with different camming. I have no idea what's available for VTXs -- it might be a solution for you as well.
NM
Stockville69
Stockville69
