VW Trike W/Auto Trans
VW full automatics (as came in Type III's - squarebacks) are quite bulletproof and well worth the extra effort if you are building a trike. If you speak of the 'auto-stick' as was used in the Type I (Beetles), then they are not quite as big of a hit (some say they are not smooth on a trike, have more problems, etc.) but are used often with great success. I think a nice trike could be made with either type, but I like the full-automatics best myself.
I have been building VW based Trikes since 2001 and have built several using the VW full automatic. Frankly, I wouldn't own anything but a full automatic. I just hate shifting all the time.
For the past few years, all my builds have been VW automatics adapted to a Subaru 1.8 SOHC motor. This has proved to be a very nice combination. A very nice smooth working automatic, coupled up with a great little motor that is nearly maintenance free.
My wife and I both ride a Homebuilt with the VW auto and Subaru motor. We just love them. As it happens, I have an extra one on hand at this time.
do you have photos, or a website ...?
i got one.full auto.put it in drive and go.didn't realize it at the time i got it,it had a bent dipstick mount that let lots [LOTS] of water into tranny case figured it out when it started leaking water out of the dipstick mounting hole.drained 2 and1/2 gallons of pink icecream out of the case.pulled the pan, [fixed the mount of course]drained it for a day,new gasket and 12[yep 12]fluid changes later,the fluid remained clear and red when drained.no prob in shifting,smooth pull all the time.only prob is the cable.put it in 2[or 1,which ever is furtherest from park[didn't get a shift indicator with it] ],come back to drive and go.otherwise it's not completely in drive.otherwise,great ride.very happy with it.
I have talked to several pro trike builders and they all said the same thing---
Type III-Squareback full auto trans are great and hold up well.
The Auto-Shift trans--not so good.
Trikerbob59,
when you said that you had "an extra one on hand..."
What exactly did you mean?
That you had a running trike on hand or a Subaru engine or a VW auto trans or
both the engine AND trans?
Thank you.
Anybody had any experience with the VW automatic transmission?? Just curious as to how folks feel about the auto trans.
I have a Roadhawk with a automatic transmission and I love it!! I would never want to go back to a standard transmission, sepecially since I do alot of around town driving, that would be alot of shifting I don't want. Lesson learned, keep an eye on the fluid,I did have a Runabout that had tranny issues but I think that was because a leak went undetected.
Highwayman 90
Highwayman 90
