Windshield Question
Nov 29, 2014
196
42
Salem, Al
Getting close to getting my first trike. The one I'm looking at has a few stickers on the windshield. What is the best way to remove these without damaging the windsheld? Petty sure using a razor blade like I would on a car would not be the way to go.
Keep in mind it is plastic and you are right no razor blade. Might try alcohol,but try a small spot to start. GOOD LUCK
I applied a state park sticker on the lower section of my windshield with
"static cling" material that I could easily peel off to transfer to my truck if I wanted to.
The same material used to apply window ads.
Once removed I could tell were that sticker was itched on my windshield when viewed in indirect light.
Why not try using what the pros use to clean and restore plastic windshields on airplanes? it is called Davies Klear-To-Land. It is the best product I have ever found to clean plastic windshields.
I get mine from a friend in the airplane maintenance business, but I am sure you can find a supplier if you Google it.
Good luck!
Another vote for "Goo Gone". Small bottle lasts "forever"...couple of bucks at WalMart or similar. Don't rush it it - spray on, let it soak in, sticker should come off easily. Good luck!
One word of caution.....Motorcycle windshields are not all made of the the material. Keep that in mind when you research cleaners. It might help to know what material yours is made of.
I just took some sticker residue off a glass jar with vegetable oil and baking baking soda, 2 to 1 mixture. I think I would pass on the baking soda on a windshield since it acts like a fine grit sandpaper but using the oil alone will work also. Might have to soak a paper towel and let it set a bit but it might be worth a try. It's cheap enough!
Believe it or not, vinegar works very well.
One of my closely guarded secrets is that I read "Hints From Heloise" with the morning comics.
Amazing what you learn & how funny it is frequently.
Dan
Yup vinegar is what I use.
Then sometimes Goo Begone for the adhesive residue.
Also keep in mind some screens have a proprietary coating on them. Never scrape it with anything.
Scraping is why Ive just gone through the expense of replacing mine.
A second of not thinking, the scotch brite side of a sponge.:AGGHH::AGGHH: Has just caused me several hundred dollars and 2 different brands of windscreens.
The 3M adhesive remover is a product I always keep on hand.
Vinager is also a good rust remover.
I've never a bad experience with anything from 3M.
I just last week ordered a new windshield from Clearview.
Anyone know of anything to avoid with the brand?
lclay23
