Need Hannigan LED Taillight Board
Larry, After talking more with Jeannette, we agreed that we should go for the upgrade rather than used parts. Sorry for any trouble I caused you. Thanks!
Best laid plans of mice and men... LED card is hardwired in. Forget the upgrade. "Does Not Replace Bikes Equipped with OEM LED Tail Light." Will order a new stock card from Hannigan. :gah:
Turns out Larry's stock taillight LED cards are new, so we worked out a deal. Card arrived today, but it is way too hot to do the swap right now.
Okay guys I too want to upgrade to the 100 light LED tail lights, however I am a little confused between this talk of plates and boards? I am thinking the plate holds the boards, right? So being the 100 light board is of a different shape than Hannigans original 14 board and plate I would need to change the plate to accommodate the new 100 light board. Right? I have four wires going to a plug under the body see attached photo, so in order to keep the same plug I'll need to splice in the four new wires.... Any clarification or help would be helpful..
Yep you're on the right track "the paparazzi". Just test the wires for function and do the same for the new boards before splice them in. Even thou the new boards are a different shape they still slip right into place. If I recall the new boards utilize the lens cover screws to hold them in place. This is an excellent upgrade and well worth doing I might add.
Larry
Thanks for the reply and verification Larry, I was getting several heads ups from fellow riders behind me saying that the rear lighting just did not seem to be bright enough... By the way how are you liking the new ride, I haven't seen anything on the forums? I believe it was the (Slingshot) was it not? Anyway sure hope its working for you....
Take Care
Ordered the LEDs 11/12 received them today 11/14 and they shipped them priority mail and at their cost! Hard to believe, however they are not cheap at $89.95 each..
Anyway as you can see from the attached photos they came with three wires and attached is a 1157 male plug setup to enable it to inserted into a stock bike socket, obviously those plugs are cut out and then spliced into the exiting trike wiring . My existing LEDs have four wires...... So I'm guessing as long as I have running, turn, and stop lights I'm good......However at the same time I'm asking my self why did Hannigan run four wires in their LEDs and do I need to run a fourth wire? and if so where do I attach it? I have set up lots of trailer wiring and some auto for that matter over the years but just not familiar with these LED's
I again would appreciate any advice and or information from those who have done this upgrade.. knock knock Larry, Cougar :cxtv::cxtv:
Okay but what part or parts do I need? Do you have a part number or perhaps pictures of your install? Is this the plate thing you were referring to? Maybe I ordered the wrong one? :xzqxz:
rvflorian
rvflorian
