***Limited Time*** 10% Savings Code on All DK Custom Lights
Jun 15, 2013
9,120
8,814
Red Banks, MS
Multi-Fit Stealth LED Front Turn Signals /White Running Lights
Kelsey
OK,
I have a 2015 FLRT Freewheeler. Which LED replacement Headlight bulb fits it? Part Number Please?
Also, I am fitting my freewheeler with 4.5 auxiliary light this winter. Any LED bulb offering for them?
Springman
...PS - a price break on a Lithium Battery would be nice.......:clapping:
OK,
Springman
The bulb at this link will fit for the headlight-
http://www.dkcustomproducts.com/Prem...-H4-HL-LED.htm
  • Item #: DK-H4-HL-LED
The bulbs at this link will fit the HD aux lights-
http://www.dkcustomproducts.com/Prem...-05-PL-LED.htm
  • Item #: DK-05-PL-LED
On a discount for the battery....call or email the shop (see contact info below) they will be able to help you some, especially if you are getting other items at the same time.
OK,
Springman
You can use the H4 LED drop in replacement at the link below. The part number is DK-H4-HL-LED.
http://dkcustomproducts.com/Premium-...-H4-HL-LED.htm
Yes, if it is the HD Passing lights, that is the bulbs we have at this link below. The part number is DK-05-PL-LED.
As for the battery we can't combine discounts. However, if you can give us a call at the office we will be glad to help you out with some sort of savings :)
Hope this helps! Happy Friday :)
Kelsey
Kevin,
Will these mud flaps replace the Tri-Glide mud flags I have installed on my '13? Is this an installation by the dealer and what wiring is required for the lighting? Thanks Barbara
Hi Barbara,
They do replace the HD brand Tri-Glide mud flaps...they share the same holes. You could have the dealership do it, but it is fairly easy to do in your garage or driveway.
It comes with step-by-step instructions, including for the wiring. It is easy, and requires NO cutting, splicing or soldering of any wires. It comes with Posi-Tap connectors that connect into the factory wiring right under the seat.
If you would like a copy of the instructions, email the shop and ask for them, we'll get them emailed to you.
Roadrunner1
Roadrunner1
