motortrike green drive shaft
miabobo
30+ Posts
Mar 2, 2019
31
6
timmins
does anyone know what year motor trike started using the new design green drive shaft on there independent rear suspension and the cost of the drive shaft. i am looking at buying a honda trike with a 2012 independent motor trike conversion. thanks in advance.
Green Motortrike drive shaft
Call motor trike they will let you know what year they started using them.
green drive shaft
i'm not sure when they started using their newest, "green" drive shaft, but am sure they sell for less then $400 shipped.
thanks for the replys i live in northern ontario canada tried to call the 1-800 number plus emailing them would not let me do it, checked one dealer in ontario quoted price was around 600.00 dollars so less than 400.00 with the exchange delivered should be fairly close. Thanks again for your input.
Some trike manufactures only sell to repair shops and dealers. MotorTrike might be one of them.
green drive shaft
i paid 340 last year in the lower 48
i checked with another dealer ( motor trike ) in ontario she got a quote from motor trike $488.00 plus shipping taxes duty also found out the updated green drive was started to be used in 2012. All this info is coming right from motor trike. Thanks for all the input in this matter.
FYI ... they make a cross brace kit, that the drive shaft goes thru, but I beleive it's only for the solid axle ones. So when you order your DS, you won't have to have that kit too.
green drive shaft
fyi ... They make a cross brace kit, that the drive shaft goes thru, but i beleive it's only for the solid axle ones. So when you order your ds, you won't have to have that kit too.
i sold a 2014 gw trike with the irs it had the green drive shaft with the cross brace and a steel loop bolted to the brace that the drive shaft went through to prevent the shaft from falling to the ground.
green drive shaft
Just installed a new front u joint in my old drive shaft the#is 437G moog product .
thanks for the info on the front u joint ridge runner i will be getting the trike in april so if it has the old model drive shaft i will be able to check it out and repair if needed.
green drive shaft
This drive shaft thing has got to be the biggest scam a company has going,, any city has driveline shops that makes shafts for all kinds of different uses, as far as ujoints before giving MT $100 plus go to pretty much any parts store and match
Stockville69
Stockville69
