New Trike - Richland Roadster Kit
Feb 28, 2019
3
11
Butler,PA
I just installed a Richland Roadster Kit on my 2001 HD Ultra Classic. I like the kit so far and I'm trying to dial in the tire pressures. On an outrigger type of conversion, what pressures are others running in the front & rear bike tires and the outrigger tires. Also looking for recommended pressures in front and rear shocks both single and 2 up.
I currently am running 30 in the outrigger tires, 38in the front bike tire, 40 in the rear. Shock pressures 10 front, 20 rear solo. Haven't ridden it 2 up yet but assume I will have to adjust shock pressure.
Looking for advise so I don't have to recreate the wheel.
Thanks!
I ride a 2009 GL1800 Goldwing with a Tow Pac setup with 12" trike tires and I run 32 PSI in them, 28 PSI in my Darkside rear Bridgestone Drive Guard and 36-41 in my Bridgestone BT-45 up front... Works well for me and I typically get 17K+ out of the rear tire and 17-20K miles out of the front tire before replacement is needed...
Good luck with the new trike kit...
Les
Richland trike
I recently had my 1991 Goldwing converted with the Richland trike kit. I'm enjoying the new ride. I currently run 22lbs in the outrigger tires, still playing with the bike tire pressures, 36 in the front and 38 in the rear. I haven't played with the shocks yet.
Phillip.........Welcome To Trike-Talk.........:clapping:.....
New member in Toledo
Has anyone installed a Richland kit on a 89 Honda shadow 1100?
Should be 98 shadow 1100. My bad. I've had nothing but problems.
tire pressure
I was told by Lane at Richland to run the tires at between 20-25 Psi.
Thanks![/QUOTE]
2011Case
2011Case
