Likes Likes:  505
Thanks Thanks:  39
Page 24 of 26 FirstFirst ... 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 461 to 480 of 504
Thread: Rebel RT
  1. #461
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default RebelRouser
    Will this work with each signal light??? Name:  LED-Turn Signal Load Equalizer for LED Light Bulbs.jpg
Size:  3.7 KB-SYLVANIA - Load Equalizer 27 Watt (at 12.8V) - Turn Signal Load Equalizer for LED Light Bulbs, Corrects Hyper Flash & Bulb Out Warning.
    JakeJacobsen@Pinterest.com
  2. #462
    Quote Originally Posted by TomyJ View Post
    That should work You should need 1 for each circuit IE 1 for front and rear turn signals and 1 for running lights, same for brake lights
  3. #463
    750+ Posts
    Jan 2010
    east windsor ct
    WHY FOR THE BRAKE AND RUNNING LIGHTS??
    I BELIEVE ITS ONLY TO PUT ENOUGH RESISTANCE IN TO MAKE THE BLINKER WORK
    oops srry about caps
  4. #464
    750+ Posts
    Jan 2010
    east windsor ct
    Led lights use low voltage. You will need a load equalizer to make them work.
    Look here https://www.amazon.com/SYLVANIA-Equa...8609126&sr=8-3
    actually in his case they are working on 12 volts but because the amps are lo the flasher doesnt work
  5. #465
    Thank you, I stand corrected Should we change amps for watts?
  6. #466
    750+ Posts
    Jan 2010
    east windsor ct
    not sure but i dont think so
    watts is v x amps
  7. #467
    Apr 2015
    Batesville, AR. 72501
    FYI: Power (Watts) = I (current)(Amps) X V (voltage) (Volts).
  8. #468
    May 2016
    Hemet, Ca. USA
    Default MerryChristmas
Size:  28.1 KBTime to take a break all, Early Happy Hour!!! And a special ThankYou to all that has helped me with this build...
  9. #469
    May 2016
    Hemet, Ca. USA
    Default RebelRouser
    Name:  2020-12-25 My Christmas Sleigh.jpg
Size:  740.4 KB-I love it when Happy Hour is all day...
  10. #470
    750+ Posts
    Jan 2010
    east windsor ct
    what happened to your floor???
    supposed to be covered w crap
  11. #471
    May 2016
    Hemet, Ca. USA
    You do not know my wife,
  12. #472
    May 2016
    Hemet, Ca. USA
    Default Garage
    Name:  2014 Garage.jpg
Size:  555.7 KBThis was my garage before the move of 2018, Finishing up on the "Trikester" and much mock up on the "RebelRouser"... "HAPPY NEW YEAR EVERYONE"...
  13. #473
    750+ Posts
    Jan 2010
    east windsor ct
    THATS BETTER
  14. #474
    May 2016
    Hemet, Ca. USA
    Default RebelRouser
    Damn I love to hear this engine running,BUTTTTT! Name:  2021-01-14 MC Brake Bracket.JPG
Size:  846.7 KBNeed to finish the brakes before a ride can happen so I need to tighten the front brakes through cable adjustment and if not I'll need to get into the shoe drum adjusters and tighten, but the rear brake master cylinder bracket will flex (1/8 wall) when I push on the foot brake so I made some side braces for the bracket (3/16) welding soon, then back to the wiring for the lights...
  15. #475
    May 2016
    Hemet, Ca. USA
    Default Bracket - MasterCylinder
Size:  714.6 KB-3/16 side braces, OverKill, Name:  HPIM5030.jpg
Size:  632.4 KB need to make metal clamp for the return spring, then bleed, check brake light switch, ROAD TEST!!!
  16. #476
    May 2016
    Hemet, Ca. USA
    Default Spring Return
    Name:  2021-01-31 M-C return spring.jpg
Size:  804.0 KBM/C return spring works, bleed the brakes many times but just not quite there??? But it does work...
  17. #477
    How is the free travel on the brake rod?
  18. #478
    May 2016
    Hemet, Ca. USA
    Default Decisions
Size:  684.6 KB-Decisions, Decisions, Decisions?
  19. #479
    I vote for finishing the rebel first.
  20. #480
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    I'm with Ted, Rebel comes first.
