Suburban Speed
139 North Main Street
Thiensville, WI
Attached to Suburban Motors (Harley Davidson)
Thiensville, Wisconsin, Harley Davidson Performance Packages, Apparel, Parts, Tools, Dyno Charts
They can accommodate an array of tuners including TTS.
My wife has a 2010 Tri-glide. Although we have a great tuner in the area of where we live (Northern IL), he does not have a two-track Dyno. I found a tuner by doing a search on the Dynojet website for a dyno center with a 250 IX (2 track Dyno. I found a Harley Dealer just outside of Milwaukee, WI that had a speed shop attached equipped with the 250 IX. I called them and discussed the fact that they were a little over a hundred miles away and could we make an appointment. They quoted a four hour labor rate although they spent more time. Well worth the cost!
I am totally impressed with the job that they did. Unlike a lot of places that simply shove a sniffer up the tail pipe as far up as they can, these guys do it right. The sniffed the exhaust gasses off the front and rear cylinder head pipes directly a couple inches down from the cylinder head.
The first thing they did was cam timing and then went to work on the map. Her Trike has a fullsac head pipe and fullsac 2" muffler cores, Andrews 54 cams, and a Alren Ness Big sucker air filter.
My wife cannot Believe the difference in heat reduction, and get up and go.
These guys are good!
Thiensville, WI
