MT comes with Goodrich Ta's
What did your trike come with, and what do you reccomend as replacements?
The brand/model/load rating designation is not important. I suggest that you look for an asymmetrical open tread design to keep down tire noise and evacuate water while riding in the rain. If you ride aggressively, a softer tread compound is also a good idea. I do not recommend a tire that is wider or taller than that specified by the trike manufacturer.
An asymmetrical tire has one side of the tread designed (sculpted0 to be on the outside to combat tread noise with the other side sculpted to extract water. I suggest that you go to your favorite passenger tire store and ask to see some of them that are available in the size your trike is equipped with. I suggest that you not let the tire salesman try to sell you tires that are wider than what you have for two reasons. (1) you will likely have a clearance problem and, (2) you wouldn't like them if caught in the rain at speed. The tire company offerings change every few months so any research I might do would likely be out of date instantly.Good points. However, for noobies like me who couldn't tell an asymmetrical open tread from a baseball, could you give some examples of what you're referring to (pictures would be nice)?
Thanks from a new trikie.
I went with Uniroyal Tiger Paw CTS....I wanted the raised white letters. Same size as the factory installed.
Do the raised white letters make the trike faster?
Absolutely, Ben. I’m surprised you had to ask.
The raised letters create a more formed and smoother wording surface that lowers the drag coefficient of each tire and creating a vortex of air emanating from each. Two or more vortices that are approximately parallel and circulating in the same direction will quickly merge to form a single vortex. The circulation of the merged vortex will equal the sum of the circulations of the constituent vortices. The resulting stabilizing downforce will increase traction, thus increasing speed.
This is the same positive effect on power and speed that is also created by the addition of chrome covering on engine components and the strategic placement of LED lighting products.
As dealers and aftermarket houses have been telling us for years, the more you spend the better and faster it will run.
Hope that helps.
Hope that helps.
I have heard that the Michelin Hydro-edge makes a great set of rain tires for the back of a trike. Is anyone running them that could give us some imput?
