Trike Dyno Locations
Thought I would start a thread on the locations of dealers and tuners that can dyno a trike.
If you know of one or several please post their information in this thread. They must have a real and physical trike dyno machine. Road dyno testing is great but there are some that need to take it to a Pro and not get involved with the road tuning process.
Comments on trike dyno operators... Good, Bad and the ugly would also be appreciated.
:wave4:
Just got my 2014 Tri-glide.. and want to remove the Cat converter.. then add on ceramic pipes and screaming eagle pipes..
After which it will need to be re-tuned.. other than Cowboy's HD - Austin, Texas.. are there any Trike dyno's closer to Houston / Beaumont area?
thanks in advance.
thanks in advance.
I had my TG dyno'ed in Lebedan, Missouri.
thanks a little further afield than I wanted to go.. looking around SE Texas / SW Louisiana even over to Houston.. I'll start calling around over the weekend to see if I can locate a trike dyno a little closer..
if you hear of anything please give me a shout.
I finely found a shop to dyno tune my 2007 Street Glide/ CSC conversion. ILLINOIS Power Sports in Elburn, Il. Jay has a built in the floor set-up with a added brake/load system. This was the first time he used the TTS Tuner but was willing to learn it. I found him under ATV etc on the Dynojet Web site. Check him out; www.illinoispowersports.com,, jay@illinoissports.com. What a difference.
Still looking for someone in the Houston, TX area who can dyno my tri-glide.
Thanks, Dale
Waco harley in Waco,texas
thanks in advance.
Waco harley in Waco, texas
I got a 03 screaming eagle road king converted into a custom trike with a procharger.I am having a lot of trouble finding somebody to dyno tune this trike for me.need help
have you tried using the Dynojet web site and their dyno locator
http://www.dynojet.com/DynoCenters/...?Address=South+Carolina,+USA&usa_distance=250
it looks like there may be a shop with a 250ix dyno near the Rockingham Dragway
http://www.ehsracing.com/
check them out or use the Dynojet locator
2 Trike Dtno's at Woodstock Harley Davidson
Was finally was able to get my CSC conversion Trike Dyno'ed at Woodstock HD, Woodstock, IL. They built one of the Dyno rooms to accommodate the width of CSC conversions. They have set up a Performance Department and are able to offer proven combinations increasing HP/Torgue for Bikes and Trikes. Great shop to do business with!
1931 South Market St.
Chattanooga, TN 37408
This guy is good with the newest version from dynojet, bikes, 2 wheels, cars, 4 wheelers, and trikes.
Colorado --- just found out that Wild West Harley in Greely has a dyno capable of doing Trikes --- I have no clue as to how qualified they are ??--------but ----staying away from that outfit in Glenwood Springs per other post on here.
I talked to Glenwood about my 07 Ultra ... they will only tune to max hp and max torq ... I wanted a more rideable tune ... wouldn't budge ... needless to say ... went to High Country Harley, alas ... they can't do trikes.
Very interested in hearing more about your trike. I've built four turbo CBX's and a blown V-Max. Installing a procharger on our 103" trike is something I might be interested in,Jack.
KRUZR; I have been reading up on where to get my TG Dyno'ed and your information really helped. Glad to here you are satisfied with the results.
Before the CSC conversion what was your bike? Possibly an 103cc Electra Glide?
What torque/horse power range did you end up with? Did it reduce engine heat?
I have a TG that need better results. Thanks in advance, DJ
Roadrunner1
Roadrunner1
