Lehman Trike Parts & Info Thread
Status
Not open for further replies.
Although it is a lot of trouble, that is the preferred method.ThumbUp
Just got confermation from a trike wrench in Jasper Il. It is a 6206 made in china. When i try to buy that its inner race is not raised.
I did get a reply from Champion. Just blows my mind. *Is this what you need for a GL1800 with a Suzuki differential? *
Did I mention I ride a VTX 1300??
BE-E00-030 BEARING $20.43 $40.86
BE-E00-031 BEARING RETAINER $12.02 $24.04
BE-E00-032 AXLE SPACER $5.15 $10.30
BE-E00-014 WASHER WAVE SPRING $1.90 $3.80
SE-E00-006 CAGE SEAL $9.07 $18.14
SE-E00-008 AXLE SEAL $9.82 $19.64
$58.39 $116.78
How in the hell do I know what I need without pictures?????????
Don't know what the axle spacer is. Don't know what a washer wave spring is. Don't know know a cage seal is. It doesn't mention the seal protector like other kits list.
Mine has Bearing, Bearing retainer, seal and seal protector. I have a new seal.
I'm thinking the axle spacer may take the place of the raised inner race but need pics to be sure.
Did you check the bearings I found for Ford ???
I have someone checking these numbers for a cross. They are exclusive to Champion. In other words... CODE :mad:
$58.39 $116.78
Bit the bullet and ordered the kit from Champion less the axle seal which I already have a new one.
Will reinstall. $20.00 for a $6.00 Chinese bearing is a hard pill to swallow!
Here is another and I think this might be it.
W206FF 30x62x23.8
Got the Champion stuff installed. 62 x 30 x 15 6206 RS. You are correct. The inner race is not raised. That is a spacer. You need the cage seal, spacer and bearing retainer from Champion. Axel seal is locally available. I recommend buying the kit from Champion less the Chinees bearing and buying a National American made bearing locally. If I have to do the right side at any time, all I will need to buy is the cage seal from Champion.
My machanic was able to save the bearing retainer and spacer
30X62X15 ???
Are you sure of the width of the bearing, 15mm ?
Can you provide me a picture of that cage seal ? Does the cage seal act as a spacer also ? I am assuming that the bearing is only sealed from one side and the cage seal makes the seal to the second side. Why not just get a bearing that has 2 seals ?
30x62x16 is a 6206RS in http://www.vxb.com/6206RS-Bearing-30...p/kit817_1.htm
30X62X15 ??? Are you sure of the width of the bearing, 15mm ?
30x62x16 is a 6206RS in http://www.vxb.com/6206RS-Bearing-30x62x16-Sealed-p/kit817_1.htm
your link is correct.
View attachment 33192View attachment 33193View attachment 33194
Yes, 16 is correct. I have a cheap plastic gauge. The cage seal attached goes in the housing first dome in. Axel seal next. The round spring goes in the Caliper mount not shown. This part you don't need as the old one is just fine. Don't know what the cage seal does. The auto world calls it a seal protector. The axle seal rides on the bearing spacer next to the bearing not on the axle. The Caliper mount is the only real Champion Proprietary part I can see. Flat part about 1/2" thick that fits between the hub and the bearing and holds the axle into the housing. Custom made for Champion.
Bottom line is: if you have a leaky seal the only parts you really need is the Cage seal if damaged (mine was), axle seal and bearing as the oil will have washed out the grease in the sealed bearing.
Went from one end of the internet to the other.
SEND ME AN EMAIL WITH YOUR NUMBER AND I WILL CALL
mnjntrpz@earthlink.net
Az Lehman Dealer
Does anyone know of a Good Lehman dealer in AZ. I am in the Phoenix area. I am wondering if there are replacement brake calipers for the Lehman. My Gl1800 is a 2007 with the Lehman kit installed the same year. I have seen new Goldwings with the Lehman kit and different brake calipers. I hate the dragging I have with the installed ones.
If this post is in the wrong area please move or delete.
Thanks for any help.
1st, Have you had the HONDA recall done ???
2nd, What issues are you having with your rear brakes and what do you want to accomplish.
This dealer has been a Lehman Dealer Installer for a long time.
Trikes by D.J.
14495 N Adobe Trail
Prescott, Arizona - US
928-273-2728
Lehman MonarchII rotors and brake pads
Lee H. Mann, I'm new to the site and missed your message. I bought my trike 2nd hand and within a month the bike shop went out of business and the Honda folks will not work on the trike part. The pads and rotors wore in less than 6000 miles. My shad tree idea did not work and I need advise. Can I put a thicker rotor and better pad that Lehman offers at a very high price or do I bite the bullet and pay the high priced Lehman price?
My trike is a 2008 gl1800 converted 2010 Lehman Monarch II.
Thank you in advance for your help.
Before I help here, did you have the Honda brake recall done ??? PM sent
99 Suzuki Intruder Lehman Vagabond
I'm not sure if that is the correct name of my kit. I bought it used last year and I'm wanting info for the kit.
Status
Roadrunner1
Roadrunner1
