Goldwing videos
Jul 26, 2016
347
124
N Ky USA
As you know there's a set of videos out there that's supposed to be pretty comprehensive when it comes to maintenance on an 1800. I have the shop manual but sometimes I can use a little more than black and white print to get me through a problem........an GoldWingrGreg is not an option as he lives too far away!
I hope I'm not breaking any rules or stepping on any toes. Has anyone got these videos? Viewed them? Got any opinions?
If you'd rather keep your opinion private you can PM me as I'm seriously considering them.
Sometime people need a video to help them get over their fear of trying ... seeing it done on a video can give them courage. While at other times, a video may show how to do something in practical steps, and a Service Manual will always give the correct step ... but they are not practicle. For example, the steps in a Service Manual says to remove the lower center cowl to replace the oil filter. The engineers that write those steps also say to torque the oil filter to 19ft/lbs. The lower cowl is removed for torque wrench access. However, most don't torque an oil filter, and know that removal of the lower center cowl is not needed when replacing the oil filter.
However, eventually you will discover that all your answers are either found in an Owner's Manual, or factory Service Manual. The more both are studied, the easier it is to find your answers. Using the index of either is often the fastest way to begin your search. Basically an Owner's Manual covers operation, storage, basic maintenance, and "how to care for your Wing," type of topics. If you follow my posts, you will often see me post, in a nice way, that "your answer is found in your Owner's Manual." In other word .... read the *ucking Owner's Manual.
I've seen some of the videos, and anyone with a strong mechanical background would agree that the skill level of the ones making them are amateur in nature. Sometimes they give advise on how to fix things that an educated mechanic would never give. To me it is obvious that none of the people making them ever spent 2-4 years in a mechanical trade school of any sort, or apprenticed for years under a journeymen mechanic. As an example, they'd probably advise people to lube their side panel grommets for easier installation. Someone who's been to a trade school would probably never give such advice. They'd probably say something like "before installing the panel, make sure all the grommets are there, and to inspect them for wear. In spite of sometimes offering poor advise, for some they are invaluable.
If any of the grommets are worn, damaged, missing or incorrect, they need to be replaced. If one finds it difficult to install a side panel, learn how by carefully watching what you are doing and the pattern one is doing it in. The pattern of which boss goes into which grommet first may need changed." After a few tries of learning how to do it, learning how to do it quickly and easily will become a learned skill. Never, ever, lube such rubber parts ... doing such can cause rubber to deform and swell.
For Honda, much of that basic advice is covered in their Common Service Manual. It's the manual one would study if they went to a Honda trade school. Usually most need help with removing/reinstalling the shelter, and learning how to remove such stuff is readily available on youtube.
Once a person learns how to remove and re-fit a shelter correctly, using a Honda Service Manual then becomes more straight forward.
When doing something for the first time, some get real confused with what bolt goes in what hole. If you step back and ask yourself some simple questions, you will soon realize why. Such questions are; why would this fastener have a longer or shorter shoulder then another, or why some are black while most are aluminum in color, or why is there 2 of these but 4 of those ??? I guess what I'm trying to say is this. Put all your fasteners in one bucket and think through putting them back in place. However, separate them at first. For example, keep all your seat bolts together. Do the same with your meter panel fasteners, and the same with your shelter fasteners. In almost all cases, there is only one correct fastener for each hole. Sometimes a parts fishe is helpful.
Also, you can always call me. I get calls from all over the world, from DIYs to other shops, and even Honda shops needing advise for free. My number is listed on JustWings.com.
Videos
http://www.pbase.com/fredharmon/root
http://www.angelridevideos.com/
Ive had these videos for 10 years for my year bike and they help. They give you a view of what youll be working on and getting into. You still need a factory manual as to me thats the bible when working on the wing but these videos are worth the money. Fred also updates the videos when Honda makes changes to the model year. I know Goldwing Gregs good but he also thinks his opinion is the right one and his way is the best way and only way. I used these videos to rebuild my forks and do my brakes along with bleeding them and the clutch. So theyve already recouped their cost compared to dealer time.
If you're mechanically inclined and have worked on cars or other vehicles you should do well with these videos and factory service manual. Sometimes you're better off doing the work yourself instead of the poorly trained tech at the Honda dealer who has never worked on a Goldwing experiment on yours. :mad: Do it yourself and save yourself a lot of aggravation when its done wrong by the untrained tech.
Thank you Gregg, excellent answers here..
Ronnie
Springfield, Massachusetts
I have both Fred's DVD's and the shop manual. Both of them are very helpful. When I want to do something I'll check both since a video can clear up a lot of words. I'm pretty sure the Chinese had it right when they said a picture was worth a 1,000 words. Video is just a bunch of pictures so do the math.
Sometimes that is so true. I used to employ an ex-Honda dealer tech who was let go by the dealer after coming back from hip operation. Although the dealer would sometimes get a Wing in for service, he said that after they reach about 12,000 they'd never be seen again. He'd tell you working here was where he learned how to work on GL1800s. The good thing was that it was a 2 way street. I'd learn things from him too.
Believe me when I say I'm a YouTube junkie. I very seldom take on a project that I don't check out some "How to videos". However there are many many people posting how to videos on YouTube and giving advice over a keyboards that should just listen & learn themselves. Reminds me so much of an old country story and the group of old men who gather an gossip each day. There's always 1 or 2 in the crowd that's an expert on every subject matter regardless.
Similar threads
JeffHenk
JeffHenk
