UPDATE: couldn't find my original post. ELECTRICAL ISSUE:
2003GL1800 w/ 2004 Roadsmith Kit no added elec access since 2016
Recently had bike apart to repair reverse, reverse module motor & cables replaced. All was well until a no start & no elec power at all occurred, battery, relays, fuses all good.
After flat bedded to shop it started immediately. Took it home, next day no start-no elec power, battery tested (questionable) & replaced, flat bedded to shop, it started immediately, I left it at the shop.
FINDINGS:no elec power to anything but when checking (+) batt termto accessory or anyattached chrome, it showed3-4 volts running thru, battery still showed 12.7 volts(+ to – terminal)?? Butagain, no power to anything.
*** When 3-4 volts show at shell or chrome of the accessory the bike (nopower) to anything won't start.
UPDATE:Fuse box removed, all clean & tight. Fuel tank removed & main ground cleaned & tightened, some corrosion showed but not much.
NOW IT STARTS AGAIN?
Anysuggestions would be appreciated.
