Hi- Just getting ready to change rear tires after 30K miles-Is that the average life of rear tires on lehman independent suspension trikes--
Hi- Out of 12 K a year 800 of that pulling a trailer with no mor than 30 lbs tongue weight- With 2 up at 340 lbs. plus 20 lbs. cargo -- tire tread is 3/32 in. outside 2/32 in. center and on far inside no tread---
Thank you Jim- I thought that with A arm suspension if its riding high or low the camber doesn't change. I must be wrong in my thinking and by adjusting the shock with more tension on the spring it should bring up my ride height and provide me with the right camber all-though my ride will be rough- Would this be something I should try?
The shock is turned out 5 turns now--
