WarBird Bike
Dec 21, 2012
7
17
Washington State
WarBird Bike is my current scratch-build, theme bike using old aircraft parts as much as possible.
Powered by a 540ci, 1942 Kinner, 5-Cyl radial aircraft engine controlled by MegaSquirt EFI......
This Kinner engine originally powered a Ryan PT-22 USN Trainer Aircraft (from the days of wood spars, dope & fabric)
Stock engine specs: 160 hp continuous at 1975 rpm (with the stock updraft carb), burns 73 octane gas, has a 5.25:1 Compression ratio, 5 inch bore, with a 5.5 inch stroke, measures 45 inches in diameter and weighs 338 lbs.
This Kinner radial engine has a couple very unusual features; there is no lube oil to the heads. Grease fittings provide lubrication to the rocker arms and push rods. And instead of a 'cam ring' (like almost all other radial engines of this period) each cylinder has its own cam shaft (so there's lots of gears inside the block to give it a very unique mechanical sound).....
Wow! That is one unique trike.ThumbUpThumbUp:clapping:
How long did it take to build it?
I can think of many more questions on the rest of the drivetrain, but will hold off hoping that you'll post a build thread on it!
That's one of a kind for sure. Where do you find the 73 octane gas? or is it 73 and above?
WOW!
CONGRATS on a Wild Looking Build Man, WOW!!!!!!! That Certainly LOOKS Clean & Neat! I'm VERY Impressed!
I'd LOVE to Hear That Beast RUNNING Though. I'm NOT On here a LOT, and I Don't KNOW IF We Can Put a Short Clip on here, WITH Sound, BUTT, IF It Is Possible, THAT Would Be AWESOME!
THANKS for Posting This Beaut Too War Bird!
ME
I'm sure you get a good number of "rubber neck'ers" looking at you as you ride down the street.......:clapping::clapping:
Yep very cool!
Ronnie
Rubber Neckers are not a good idea :AGGHH: ... I used to put a canoe on top of my Time Out trailer ... pulled both with a 2004 Gold Wing ... did that twice, both times there was a wreck near me ... guessing they were more interested in looking at me and not the road. LOL ...
Kewl trike ... very unique. I have a bunch of questions ... but, I will allow them to percolate and maybe get answered on their own ... but the biggest would be ... is it aluminum, SS, hard to tell from the pics ... so the question is, how long does it take to polish all that ... :AGGHH: ... just kidding ... I for one applaud you for the effort, not gonna find another one I bet ... way kewl ... :clapping::clapping::clapping::clapping:
that thing is scary looking, the dash is intmanating, but I would like to watch it run
AndyX
