- Thread starter
- #21
Thank you for your input I tried to check that as best I could. The new oil cooler looses only about an 1/2 to 3/4" to the old OEM. I don't know of a way to fully compress the forks to see. As you can see there is a little difference I made every attempt to keep it as low as possible to avoid interference with the fender. Any suggestions on how to compress the forks would be greatly appreciated. ride safe FredLooking forward to seeing how this works out...you should get a nice result in lower temps.
One thing I only now just thought about. Have you fully compressed the front forks (simulating hitting a big bump) to make sure there is clearance between your fender and the new oil cooler?
