Does your Freewheeler idle smoothly?
DW's 2022 FLRT seems to surge (a little bit - maybe 100 RPM) about once every second or so at idle. Doesn't seem normal to me so I wonder if anybody else has this problem.
It's an M8 114c.i.
My twinkie doesn't do that and her Evo before this didn't do it.
It's an M8 114c.i.
Check to see if your bike's EITMS system is activated. If it in on, what you describe is exactly what happens.
When you are stopped in traffic the EITMS if enabled will kick in and idle will be up and seem uneven
If you do not have the EITMS enabled it should idle smooth and not vary up or down +or - 10 RPM, typical( idle set by the computer is ) 950
How do I check if EITMS is activated?
Every SECOND it surges?
EITMS can be enabled or disabled by performing the following procedure:
1. Turn ignition switch ON. Push the engine OFF/RUN switch on the right handlebar to the RUN position.
2. Push the throttle to roll-off position and hold.
3. See Operation -+ Instruments - , Indicator Lamps..
4. Repeat the procedure to enable or disable EITMS.
I've rode some M8's that the engine surged like your speaking of. I haven't been mine since December but I don't remember it doing that. Hopefully I'll get a ride in a couple of weeks and I'll pay attention to that. It's under warranty take it to the dealer and have them look at it.
Finally got around to trying disabling EITMS. I did it several times and it made no difference whatsoever. After warming up for a couple of minutes with smooth idle, it began surging around 200 rpm every second or so.
It doesn't bother DW who rides the trike (she doesn't hear it) but it bothers me when we sit beside each other waiting for a light.
Have your dealer look at it under warranty, it should not surge like that
Sorry it did not help. Since it is a 22, once the weathers get nicer, consider riding it in and asking the service guys to take a look.
Good luck
Daddy Lew
