Electrical Issue 2022 TriGlide
Mar 8, 2023
38
30
Levittown, PA, USA
[FONT=&quot]Need some assistance. I was changing my levers on my 2022 Tri-Glide. I did the clutch side first and tested, everything was okay. After doing the brake side I developed an electrical issue.Headlamp, tail lights, brake light (if rear brake pedal is applied) and fuel pump work fine. Nothing else does (i.e. No start, no radio, no horn or turn signals). I checked all the fuses and they all look fine. I even replaced them.
[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]Any thoughts?
[/FONT]
Any thoughts?
Those brake switch's break / damage easily they are very delicate, You might need a new one..?
Did you take the switch half's apart when doing the job?
See # 17 below
Medium
I gave up and I'm going to have the dealer pick it up tomorrow or Saturday. I'm actually pretty mechanically inclined and do well with electrical crap, but this 1 has me stumped.
Post back when you find out, this will surely help others in the future
Best of luck to you
I had something like that happen to me when I installed heated grips on a 05 ultra a few years back. The speedometer, tach, the lights in these gauges, directional's, horn and radio controls on the handle bars were all dead. None of the warning lights in the speedo would work. It would not give any codes but the 4 ways would flash 6 times when the ignition was turned on. It ended up being blown fuse for the accessories. The grips were wired into the accessories plug in the fairing and one of the wires got pinched and shorted out in the handle bar. This probably wont help you but these things can be a big pain. If you have a short, they can do funny things.
Problem solved...pinch wire in the clutch side. Bad news is that I need a clutch safety switch
Don't feel too bad.......There have been numerous safety switches on the handle bars that had to be replaced after work was done on the bars...Like putting on new grips or new levers...ETC.....Those switches are delicate...
Actually all is fine now. I did not realize that in order to start the Tr-Glide in gear that both the clutch & brake must be applied.
Doesn't make any sense ......If you go back it your first post you say....No radio no horn no turn signals ??....The cluch and brake Do not need to be applied for them to work..:Shrug:...........
The main/only issue was a pinched wire at the clutch perch which was cause al of the electrical issues. After resolving that issue, I tried to start the bike in gear with only the clutch engaged. At that point I assumed I had screwed up the clutch safety switch not knowing that I also had to apply a brake.
Thanks for Splaining it more better..
Drew73
Drew73
