You are not the first, nor last to to that. I did it (but with a #2 pencil) on my 95 Road king while changing cams and tensioners. Not to mention when mice filled my Rinehart mufflers with deer corn from then feeder. No damage, except that it scared the sh-t out me when I cranked it up and sand blasted the garage wall with deer corn! 😜 🤣
I can’t tell you how many times I’ve dropped the wing nut inside my Carter AFB’s Carburetor…And as far as Corn/Acorns and seed that’s a given with my ATV’s after sitting a while in the pole barn…I had to start spreading moth balls all around the machines to keep the rodents away..
Bought the AM/FM & CB antenna, conversion wire harness to install my ProBeam on my 21 …got the bike flashed for the CB and the passing lamp to stay on with both high and low beams.. awesome.
Installed a Rekluse clutch slave cylinder on my '18 TG. All I can say is WOW. It will most definitely help with my arthritic left hand and wrist. It is all of the advertised 30% lighter clutch pull. Only downside so far was having to drop the exhaust to get the cover off.😵*💫. Bad planning Harley engineers.
We did a breakfast run yesterday, about 80 miles round trip then spent an hour cleaning the love bugs off. Probably not going to ride for a week or so because of those buggers, they're very acidic and need cleaned off right away.
You have to understand......Engineers and for the most part designers don't ever work on things that they engineered/designed .....Thats not their job ..Their job is to make it last till the warrteny runs out and to look pretty while doing so....:D...
Believe me, I understand. I've been fixing engineer screw ups my whole career.😵*💫🙃😂
And did any of them amid that they were wrong… the closest you can ever get them to admit to being wrong is when they say that’s Not necessarily so… lawyers will also use that line when they are wrong..
Sylvester
Sylvester
