Has any one tried one of these on their 09+ TriGlide?....
I did put a dampner style link on the front of engine, but wondered if one of these would be of benefit as well?????
HaNkB
Mike...I was referring to the powertrain twisting in the frame, not the frame itself twisting..it seems as even tho the powertrain is mounted on 4 isolators on the 09+ that they still twist..This is what puts strain on the upper front link which tends to break the bolts in the head off...Now that iv put a dampened link on there, it appears to me I have allowed the powertrain to twist, somewhat like the previous 08- version on just 3 isolators...This kit appears to mount to the starter bolts and frame to keep the rear of the powertrain from twisting in the frame...Not sure if its a good idea or not...
Im just reaserching the product too see if anyone has actually put one on a 09+ chassis, 2 or 3 wheeled..HanKb.
I have to do some revitalization on this thread
At the moment I have the problem with a broken bolt on my front motor stabilizer. Hopefully my mechanician can fix it fast, because it's season opening :gah:
The threadstarter mentioned the Alloy Art Touring Stabilizer - has anyone installed this thing on a Tri Glide?
How is the experience? Especially with a view on the front stabilizer and the force on it?
When Harley designed the frame for the Triglide they beefed it up, I'd be shocked if it twisted. I've had the front end up a couple times, done some burnouts and hammerd many of windy roads and never felt any flex. I'd be hesitant to stiffen things up more than they are.
Unfortunately it is a problem, because it is the inner bolt, covered by a frame tube and, it broke about 0,2 inch deep in the head.
The thread fortunately seems to be intact, but he has to pull the head, for a save removal of the remaining part of the bolt :xzqxz:
Today is a holidy, he can provide the head seal tomorrow, Monday is the next holiday, so the work starts on Tuesday ... hopefully, the head has no further damage.
Anyway, fortunately this is covered by warranty.
If it is covered by a warranty?, You did say its a 09...:Shrug:
Then outside of the downtime....Problem solved.....
I think he was saying the stabilizer fits an '09 to present.
