2003 Lehman Monarch II
Cyber I had a part number written down somewhere. Don't think they can be had from Lehman. So I had a cross ref number done and located. Believe my Honda dealer actually carried them. If I can find the darn thing I will post it here. I have 05 Monnarch II..Just haven't needed brakes yet. Maybe somebody know in the mean time..Dogman
cyber looking thru lehman paperwork, I see Lehman Dealer in Salt lake, if still there...Wasatch Trike
801-898-7453, wasatchtrikes.com...Maybe help there? Dogman
cyber, I got on line and searched for dealer located in Va and near me, contacted him, ordered new pads(about$70) and now good to go. Should be same for your area.
2010 GL1800/Lehman Brake pads
After searching for rear brake pads for my Monarch II, I finally had to get them from Champion sidecars out of California. The year is a must as they used a couple of different calipers on the solid axle over the years. then get the credit card out lighten it to the tune of $150.00 yep you read right $135.00 +tax + shipping = $150.00. Champion told me trikes use small calipers to keep the size of the braking system down, automotive calipers would require an automotive master in order to operate the calipers (fluid volume). The only exception would be the trikes that still use the original G/W rear end as part of the kit then you could get pads from a bike shop. I'm keeping an eye on mine I'd hate to see what a rotor would cost!
Lehman Brakes
http://www.triketalk.com/forum/threa...-II-Brake-pads
Rotors are $199.00 each plus shipping.
Don't beleive everything you hear. I have Champion SA on my VTX. OEM Honda master cylinder with VW disc brakes on a Suzuki rearend.
I asked Champion what my rear is and what the make of brake pads are the only answer I got was this.
"The rear end is our own----you can purchase anything you need directly from us
brake pads run $116.76 for a complete set (both sides)" Nice to know I can get pads there but would be nice to shop around. Whats with the mystery some of the makers have? :Shrug:
Disc Brakes
11” Disc / Dual Piston VW
Pads - #311 – 698 – 151B (Pads) Bendix #DB15, Federated #D30A, EBC #DP-4105R Yellowstuff Pads
Calipers - #311 – 615 – 107 & 108 (Calipers)(Beck / Arnley #0770229S, Cardone #19 – 230 & 231
Thanks to Solidbob
Disc Brakes
Thanks so much set PM thanking you also +1
Disc Brakes
Your welcome, this was my Post.... as Roadsmith uses the same parts..... and VW Brakes
tw0fast4u
tw0fast4u
