ATV rear differential?
I have no wobbles, steering is excellent now. Without dampers when I'd let go of the bars bike would pull slightly one way or the other depending on the road. With the dampers fine tuned steering stays perfectly straight which greatly enhances the cornering ability not to mention confidence. On my Fazer they are mounted on each side of forks, my gsxr600 has them on upper and lower forks as seen in pics. Got them on Ebay, work excellent. Had to make custom mounts for them on the Fazer.
so that means u had wobbles before u put on the damper??
[QUOTE Without dampers when I'd let go of the bars bike would pull slightly one way or the other depending on the road. With the dampers fine tuned steering stays perfectly straight [/QUOTE]
what you are saying is it acts like a spring to stop that pull .. correct???
what you are saying is it acts like a spring to stop that pull .. correct???[/QUOTE]It just stiffens up the steering so it tracks straight.
joefontenot
joefontenot
