Center Stand on RS Conversion
If it will have running boards,center stand can't be used if they even leave it on.
I opted for no running boards on my GoldWing/CSC conversion and still have the center stand which I use many times.Have had all three wheels and tires off the bike at one time using the center stand.I drive it onto 2 2' pieces of 2x6 boards cut on 45 degree angles on each end.Makes it easy for 1 person to pull it back onto stand.To remove rear wheels I use a small bottle kack under receiver hitch for just enough clearence to get wheel off.It will also give you a little more clearence underneath for oil/filter changes.
Biggest thing is that it helps the wife to better clean the underside.
I'm happy I kept mine.
I'm opting for no running board, wing guards as called by Road Smith, so thought I could use the center stand for something if left on the machine. I questioned the installer their response was they had no idea what it could be used for and why would I want it. Thanks.
