custom corvair engine trike
May 1, 2021
1
5
Carsonville mi
this is my custom trike. this is a home made trike, don't remember guys name. my dad purchased this in the early 80's. The trans is a vega air cooled gmth350, the engine is a corvair flat 6. the first picture is of the neck that is currently on it. i had a guy install this and was supposed to help finish project but he is not returning calls. i measured angle of neck and come up with 45degress. i have purchased a front wheel of 19". i figure trans weights 120 lbs and motor is 225 lbs and add for driver. i hope this angle is correct and need to order front end to match. interested in your thoughts as to what to use for best results. thank you
View attachment 98631View attachment 98632View attachment 98633View attachment 98634
i would plan on a set of raked trees or a leading link front end.... you are going to have a lot of trail ...= hard steering
Welcome to the forum from Western Pennsylvania stop by often and check in with us. Great project those motors are good ones.
Similar threads
lclay23
