Display is BLACK
May 12, 2021
2
1
Dalington
Question: I have a 2010 Audio Comfort with only about 8K miles on the clock. 2017 Road Smith Kit. Over the years once in a while my display would just be black, now it is almost every time I start it. I have reset all the plugs on the back of the display. Thoughts? Suggestions???
Welcome to TT Steven. It will help if you identify which bike your kit is installed on. Make, model, etc. I'm sure you will find some helpful information here..... Jim
His original posting says what his bike is
OK. I see your profile picture shows you have a Honda GL1800. Do you also have nav. on the bike. If so, the display loops through your navigation electronics housed on the front wall inside your trunk. Take the cover off and you will find a little pin hole in the top of the unit. That is a reset button. You can use a paperclip or something to GENTLY push down and reset your system. Do this with the key on and watch your screen. Don't push too hard. You don't want to break something. You don't need to remove or unplug the nav unit. This is a pretty easy process and only takes a few minutes to do. Good luck..... Jim
Jim, I did as you suggested... Sadly no relief.. Still Black. I am afraid the screen may be burn/shorted out. It has done this once in a while even before we triked it. So I am going to pull it off, clean and check all contacts/plugs, and see if that helps.
Thank you for your suggestion.
Steve
Next, I would call Mark DeSimone At D&D Discount Motorcycles in Tempe, AZ. 480-731-9003. Mark is the technical writer for Wing World magazine. He KNOWS Goldwings and may have some insight for you. Again, good luck and welcome to TT..... Jim
Excellent suggestion here::: I just put his number in my cell phone myself............
rramo
