Light gray color streak in display screen
My guess, the LCD is going bad ... I had a similar issue and ended up replacing it.
I would disconnect the battery for about 5 minutes ... try it again, if it doesn't clear .. probably gonna need replacement.
It's a bugger of a job and the new one is pricy unless you get lucky.
Here's what I had
Honda wanted $1700 for the new LCD and $300 to install it. I found the exact same LCD (direct plug and play, same Sharp dpart #) for $110 shipped from eBay. Not gonna lie to you the replacement was a bugger. The big problem is there is not enough wire to unplug it from the cockpit area. I had to tear down the entire nose just to get my paws on the plugs. Once it was unplugged, it came out fairly easily from the cockpit.
Good luck
joefontenot
joefontenot
