- Thread starter
- #41
Very nice looking! Did you route it to the wiring/lighting plug under the seat?
Nice work Jeff
I cant wait to see the signals work
.... MT's and Cragars on the way. .....
....MT's and Cragars on the way...... .
PS.....
If you have not already thought about it...You will need hubcentric rings for your wheels to line them up help to dynamically stabilize them. Harley's hub is 2.5" diameter. So the hubcentric ring ID will be 63.4mm. My Cragar wheel adapter required a 72MM OD. You will need to measure yours to see what is required. The guys at US Wheel Adapter had exactly what I needed off the shelf. They can make custom ones for you as well. Here is a link
https://www.uswheeladapters.com/hub-centric-rings/
She is a beauty. Good luck.
P.S.S.......
You might want to look into DK's heavy Duty Axle Bearing Retainer Plates (see below). They will help with some of the bending moment changes wide wheels/tires will place on the axle and differential loading. Just sayin...
BTW.... It has been a BEAR getting someone to press the bearings off and press new ones (mandatory) on.... I have been down for three weeks due to this issue. So plan ahead...
How's your progress?
I have been at a total standstill (without the trike) for three weeks waiting for the bearing press job from my local dealer. They do not have the ability to do it and farmed it out. But it must be a slow growing season at that farm because my trike has been torn down and sitting too long. My triple trees were supposed to be complete a month ago, but the guy doing them is behind so the front end work is delayed too. This project has had a lot of hurry up and wait. I was ok with all the waiting up to this point as it did not interfere with riding. But this phase has been a drag. It will all come together soon though I'm sure. Looking forward to Fall rides on the River Road north of St. Louis
I probably ride that way to Grafton, IL & Pier Marquette state park ...Don't go down 94 to get there,
I love the out of the box thinking ... so kewl. Curious how all the rubber is gonna handle/ride.
