Harley Fluids What and Why!
That's my opinion and I'm sticking to it.
Amsoil is still cheaper then H-D Syn3 and a much better oil.....in my opinion.
Different oils for different holes isn't a bad thing. Just the convenience of one oil. And if there is an internal leak, it doesn't contaminate the hole it leaked into.
What I do is go to an independent testing place and look at their tests for any given oils. Compare their results. You might find the oil you have trusted for years is lagging far behind related to others.
One thing I have found, is Amsoil is quite "self critical" on their products. Also they go to length to explain what the tests mean, and why. I've been very happy with Amsoil for many years ! That doesn't mean it has to be the same in all holes, Harley says you can do that. If you would like to use different in each hole, & you have good luck with that, by all means do it !
:Trike1:
Harley also said if you use syn oil you will destroy your engine.......until they saw lost $$$$$$$ then it became great to use syn oil - - - but only theirs. :D
I have a ultra classic and had a Royal Star. I use synthetic for engine, where are the other two holes, I know one is for transmisson what is the other (clutch)? It is a 99 Harley wit Renegade trike kit.obiesdomain@verizon.net
One is for Engine oil, and the other is trans. You also have to put oil in the primary case through the derby cover on the left.
You need to purchase at least an owners manual from Harley !! What model Harley is it ?:Trike1:
syn3 h/d in all.. Me have a sportster xl1200l/motortrike bike. After I have to do a clutch overhall I wont be using syn 3 for the clutch. I use it to reduce the heat.
Redline 20/60 in my engine, why? It's the only pure group V synthetic and the ambient air temps are high down here. Belray 75-140 gear saver in the trans, why? HD dealer here uses it on every bike they sell at the 1K service. Advised me that it will not attack some of the parts inside of the trans. HD primary + in the primary, why? Seems a consensus of the members of several forums that it helps with the SE compensator fretting issue.
My primary was removed a few weeks ago to install an SE clutch diapragm, ClutchWiz and Hayden M6 chain tensioner. So far, no evidence of a compensator problem or any metal in the primary. That's my story and I'll stick to it.
I also use the Harley syc 3 in everything on my 2010 tri glide ,carrying on trips one kind of oil ,made trip to Daytona and up north to wasington and never had to add a drop. used in my other bike also and it had 54000 miles on it without a problem
Ok folks
I've opted for a mechanical reverse to be put in my 12 Ultra as part of the Motor Trike kit install.
Anyone running Redline shockproof or AmSoil Severe with a reverse gear added encountered any issues?
syn 3 is waaaay tooooo thin for the tranny. use red line or spectro.
i use rel line its motorcycle gear lube is syn. & is pink in color, so if you have any pink in the oil when you change the primary, you know you have a seal leaking.
also like their 20x60 syn oil for the engine. can't find anyone else who makes a 20x60 wt. oil except r/l. in the heat of the summer you nees it exp. in traffic.
I'm new to Harleys, I am getting close to my 1000 mile ck. on my 2013 T/G,
I am really confused on what is the best oil's to use, I have read all 10 pages of the sticky's on Harley fluids and it seems few people can agree on what to use:gah:, from the few that do agree on syn. 3 and by what the Harley manual recommends it looks like syn.3 would be the best guess:Shrug:, esp. for someone like me who knows little about what is best.
Some here says syn.3 is to thin, some say it will make you clutch slip, or that it was no intended for you transmission or the chain drive:gah:.
would I be wrong to go with syn.3 to start with? until I learn more about the diff. oil's, or would the ones who do not like the syn.3 feel that I would be making a big mistake.....A new guy to Harleys:).
Throw another in the pot. I use Amsoil in all three. 20/50 in the engine & primary, 75/140 in the transmission. Harley says you can use 20/50 in the trans also, but then they also sell parts in my opinion ! IT IS way too thin !
Some like the Redline products, & they are top of the line also.
:Trike1:
You can get tons of information about fuels and lubricants on this forum and some of it, by chance, will be accurate. <grin> The only reliable source of information regarding proper fuels and lubricants is the vehicle manufacturer. The subject is covered in owners' manuals.
For what it's worth...
I use Valvoline racing oil 20-50 in the crankcase, Dexron ATF in the primary, and Redline HD Shockproof in the trans of both my 2001 Softail and 1997 FLHTC DFT trike. I change engine oil every 3000 miles and the others when I think of it (which isn't very often, especially with the trans).
At about 85,000 miles I swapped out the stock 5-speed Softail gearset for a Baker 6-speed. No discernible wear with Valvoline 75-90 synthetic transmission oil in it (for about the last 50k without a change). A guy bought the 5-speed gearset from me and put it into his Softail. I's still working fine. I put the Redline Shockproof in the 6-speed because Bert Baker recommended it. (Yes, he's a manufacturer, but he's not promoting house-brand stuff. He's also an engineer. As an engineer, I tend to believe other engineers a little more than corporate PR guys.) I do think the Redline stuff is pretty good. It's also expensive if I changed it a lot, but I don't. (BTW, a lot of new cars don't even come with rearend drain plugs anymore. It's a "lifetime" deal. It seems to me loading on motorcycle gears is a lot less than automotive differential gears.) Anyhow, it worked for me.
At 96,000 on the Softail, absolutely no oil usage, no varnish at all, no valve guide wear or cylinder wall wear, no piston skirt wear (teflon coating still in place). I only tore it down to do a 95" conversion. Again, it worked for me.
I've tried Type F ATF in the trike trans but it made the clutch kinda grabby, so I went back to Dexron. No clutch slip, no appreciable wear on the chain or compensator.
>>...The only reliable source of information regarding proper fuels and lubricants is the vehicle manufacturer. The subject is covered in owners' manuals.
Information in the best interest of the manufacturer, yes. Best for the customer or owner? Maybe yes, maybe no. You can at least be pretty sure that the manufacturer's recommendations will get your ride out of warranty. ;-)
BTW, I'm sure we're all aware that motorcycle manufacturers do not manufacture their own oil, they contract it out to a petroleum refiner. For quite a while, HD oil was manufactured by Valvoline. I understand the manufacturer is now Sun oil. It's pretty easy to have an analysis done on additives to determine what contains what.
Just my experience.
The compensator in the 07 & up doesn't care for ATF, especially the Screamin Eagle compensator. They seem to live the longest using the Formula+ from HD. I agree 100% about the Redline Shockproof in the trans, its good stuff.
Oh what the hell, I might as well throw in my 2cents worth. This is what I use and am very pleased with this combo. Engine: Mobil 1 20/50 V-twin Trany: Red Line Shockproof Primary: Red Line Primary Fluid :Coffee:
I use Amsoil 20/50 in the crankcase and primary. Amsoil 75/90 in the tranny. Seems to shift into gear smoother, but it's still almost impossible to find reverse. The Harley loud clunk when shifting into first is still very much a pain in the A$$. A clunk, to me, is caused by two or more pieces of metal smashing together, and that can have no good ending. Adusting the clutch per Clutchwiz's procedure hasn't helped.
Oh well, I will just have to assume that neutral isn't "findable" except when the engine is off. Then it is a piece of cake.
Yeah, Harley. You did it again.
Finding reverse or finding neutral?
The clutch adjustment procedure on the ClutchWiz.com site is just for those who use the CW. Stock retainers will use 1/4 to 1/2 counter clockwise turn of the adjustment rod in the primary after finding zero lash. (Zero lash = clutch lever just starts to pull away from the grip.)
Zero lash is not the "Dead Spot". The DS is the distance between the grip and clutch lever that seems hard to pull in and does nothing but stretch the cable.
Oil in the primary is really not for lubrication, well... it is but it's only primary chain lubrication and for the compensator. The clutch uses oil for heat rejection only. Any oil will do as long as it doesn't upset the clutch bands.
Some say that Synthetic oils are too slippery for the clutch bands. That information can be misleading. A normal Synthetic oil is just fine as long as you don't use anything heavier than 20-50. Thicker oils tend to make the bands stick when cold which will create a "creep" in the clutch. This will cause your bike to slightly jump forward when putting it in gear while the clutch lever is pulled in or you may have a severe creep and the bike will continue to roll forward at a stop light.
Harley makes a lubricant especially for the tranny and primary. To me, it is too thin to use in the tranny but perfect for the primary. The thinner the lubricant the faster it will reject heat. This product is called "Formula +". Those who use racing clutches will mix Formula + with ATF. (15 oz ATF with 30 oz of Formula + in a dry primary, 3 oz less AFT when doing an oil change) This thins out the primary oil for more heat rejection.
If you have adjusted your clutch many times and still have issues finding neutral, what could be the cause? Here are some things I've run across. Others may add to this list.
1. Cable stretch beyond the cable adjuster.
2. Damaged or warped clutch bands or steels.
3. Worn or damaged right side ramp (cable attaches to a factory ramp)
4. Primary oil level high (or low level)
The #1 reason I find is adjusting the clutch when cold. The bike and clutch assembly should be warn before adjusting. This is when using a stock clutch retainer. For the ClutchWIZ, it is adjusted cold.
:wave4:
HomeFree
HomeFree
