Yes w/ Trike Lift – HD Tri Glide and HD Freewheeler *No Conversion Trikes* |
Hello All
Was wondering if anyone has used a J&S standard motorcycle jack
to lift a Freewheeler? I have messaged J&S about this and am awaiting a reply.
I would only lift just long enough to reposition in the garage and keep it
VERY close to the ground
Thanks very much
Dante
I use a Harbor Freight jack that I upgraded the hand pump portion of jack to 1.0 ton. Got pump at Harbor Freight then for around 20.00.Most motorcycle jack stands are made quite sturdy,but the pumps they put on them determine the lift capacities. Freewheeler would need at least a pump jack rated at 3/4 of a ton at minimum.
According to a chart on the web sight. For trikes:
Must be the trike jack.
