Q Quietrider Aug 29, 2017 #1 Is there a tool to help get the muffler clamp back on once it has been removed?
C Casper 400+ Posts Aug 29, 2017 #2 I use a pair of Chanel Locks the help spread the clamp as I slide it back into place...
Jack Klarich 18000+ Posts Aug 29, 2017 #3 Casper said: I use a pair of Chanel Locks the help spread the clamp as I slide it back into place... Click to expand... # 2 on this 1
Jack Klarich 18000+ Posts Aug 30, 2017 #4 You can find these cheap @ Lowes they are for spreading large snap rings
Jack Klarich 18000+ Posts Aug 31, 2017 #6 1 more thing about these clamps I know we aint supposed to use them over { some times I am CHEAP} the wedge piece in the middle of the clamp can be ground down a bit This will make the clamping force better JMO The wedge is seen in the middle in this pic I also change the splined bolt for a new bolt, lock washer, 2 flat washers ( 1 for each side of the bolt) and a new nut for better tightening
