Rebel RT
RebelRouser
Floored and on dollies.jpgFloored again on furniture movers, front breaks static check, and the chains lock up, AGAIN, last time took the jack shaft apart and everything works fine, can rotate the wheel in reverse all day long BUT forward will make 1/2 to 3/4 turn then sudden lock up??? AND... the engine shift lever is hitting the exhaust 1/4" BUT on the bright side I'm getting closer. I know I'm thinking a little ahead of myself BUT will a short video be down loaded of it running around the block? Does anyone know???
Looking good. On the chains locking up, are you turning the rear wheel forward by hand and pushing all the slack to the top ? Could it be causing it to bunch up in front of a sprocket? Turning with engine power would put the slack on the bottom and not cause a problem.
RebelRouser
Floored chains OK.JPG-Chain Gard was the problem, Now back to the engine shift lever and the wiring, Oh! Fuel lines and FUEL... EDIT: Thank you fuzzman you are so right, I made the POOR quality video and it will not download here, MAYBE PINTEREST?(NOT) But it did work in FB under, Reverse Trike owners and builders...
RebelRouser Video
Here is the video on FB:
[video]https://www.facebook.com/n/?video%2Fedit%2F&v=1006011393183986&aref=159917702 5653982&medium=email&mid=5ae7120f60a0cG5af6267ae78 aG5ae716a8c0cdeG3d&bcode=2.1599177025.Abx4JwhG2D0B 425cMPo&n_m=tjakejacobsen%40yahoo.com[/video]
Did not work for me? AND: Pinterest did not work?
Does not work, However I have been following your build and I wanted to say you have talent and a good eye at design. Best of luck to you:clapping:
View attachment 91710Support group make things a little easier, one wire a day and early "HAPPY HOUR"? or is it, "One wire at a time"? :clapping:
Wiring is a big pain, take your time and get it right the first time. Are you making your own schematics as you go along for future reference?
RebelRouser
Hi Jack, :Dorag:, or is it High Jack, :xzqxz:, Thank you for stopping by, I have to extend the front and rear lights harness (diff colors) and the plugs go from one color to another according to the Honda book.
Wiring front lights
Front end wiring.jpg-HPIM4780.JPG-HPIM4781.jpg-Front wires are wired together and routed to the harness, but not connected yet, I will double check my ignition wires first and see if I can get it to turn over and start, :clapping: OMG! I'll need extra strength toilet paper (Charmin extra strong, boy that will clog you crapper for sure, :D) for this one because you gunna know I'll sheet my pants when it starts, video for sure...
Always super alert when putting power and fuel to a new creation....most times safety switches etc. not connected, so double check neutral on the tranny. Be ready to disconnect the battery and have a fire extinguisher handy....then time to light up! Good luck!
Halloween
Halloween-2020.jpg-Tank and seat for photos, front and rear wires not installed to harness yet, will try to get the engine to at least turn over (no gas tank) but for some reason I'm getting a red light in my battery charger (Black and Decker), hooked up a 12 volt interior bulb (test light) and it works fine? :gah:
View attachment 92427-Tank and seat for photos, front and rear wires not installed to harness yet, will try to get the engine to at least turn over (no gas tank) but for some reason I'm getting a red light in my battery charger (Black and Decker), hooked up a 12 volt interior bulb (test light) and it works fine? :gah:
What is the voltage reading of the battery?
Damn Battery
Thank you Jack but I do not have, so I hooked 2 little jumper wires straight from the battery to the horn and made a little click,:Shrug: So I got 1 of my eScooter batts 12V and wired it the same way, heeheehee, scared the wife with sound. Ordered a new battery from eBay this morning, :clapping:
Roadrunner1
